V6 OBD-II Swaps - Need Information
- Newfie_dan
Re: V6 OBD-II Swaps - Need Information
you do not need to swap any engine harness with the obd2 car all you need do is drop the engine in, plug in the sensors and swap the vaf for one from a 2.5 v6, the only issue that you are going to run into is incorrect vris points. Daninski did the swap and I have talked to others who swapped to the klde and klze with the obd2 setup. The only disadvantage is that you can not chip the obd2 ecm.
You can mega squirt and use MSD window switches. You just have to figure out how to mega suirt as that system uses the cam sensor in the disty and the 95-97 doesn't have a cam sensor in the disty. I think just using an older disty but reversing two of the three wires on the one disty plug will work.
Hey way to revive an old thread.
this thread is 3 years old boys. im sure the op is long gone and/or solved his problem
No sh*t Batman, didn't you read my post. But hey thanks for pointing out the obvious.
no i read it. i just figured you were some ignorant racistDaninski wrote:No sh*t Batman, didn't you read my post. But hey thanks for pointing out the obvious.
Either that or someone who likes to discourage spammers from frequenting this site.
Wisdom appears in contradiction to itself, which is a trick life plays on philosophy of life.
See mikeinaus, spammers. In your face.
Ok Who forgot to take out the trash?
[thread cleaned]
[thread cleaned]
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Ancient Chinese Secret!Diana wrote:Wisdom appears in contradiction to itself, which is a trick life plays on philosophy of life.
OK just before my post was a post (advertisement) for a suppler in China. The person must of saw my post and deleted their spam post. Did anyone else see/read it?Daninski wrote:See mikeinaus, spammers. In your face.
