crank no startm changed distributor now starts but hesitates
mrwhite
Post by mrwhite »
No spark so changes distributor . Now runs and starts but. Hesitates stutters..when yu give it gas it wants to die.. any suggestions ideas thanks
Ryan
Re: crank no startm changed distributor now starts but hesit
Post by Ryan »
set your ignition timing properly in diagnositic mode with a timing light. You may have noticed that the distributor is adjustable. You could just adjust it until it runs right for a temp. fix.
mrwhite
Post by mrwhite »
Yea I adjusted to just to get it started than adjusted it while giving throttle to get it running smooth. What's the timing procedure? Or if u can direct me to a link ?
Thanks for your help
Ryan
Post by Ryan »
http://www.mx-3.com/manuals/showimg.php ... F2-073.gif
And if it still acts up... it could be a few different things. Fuel problem, spark plugs, wires, cap, rotor...
Post by wytbishop »
carefully inspect the intake hoses for leaks. In my experience most idle problems are traced to an air intake issue. After that set the TPS, the timing and the idle according to the procedures in the manual. If the problem persists start looking at the other ignition components. Bad plug wires are a common problem, incorrectly gapped plugs...that sort of thing.
mrwhite
Post by mrwhite »
so it turns out it was a bad reman distributor..replaced it today and started right up. new cap also..im doing fuel filter tomorrow afta work. \
thanks alot for your input
