An affordable big brake kit - feeler thread-
- mitmaks
Re: An affordable big brake kit - feeler thread-
I already have s/s lines, would they work with this kit?
- jaydog5678
No, I had to use a company that makes lines. The fittings on the Wilwood calipers won't work with the stock lines.
This project is done Mitmaks. I really don't have the time to invest in this again for others right now. Perhaps next summer I will. If I start getting P.Ms and emails saying that they have the cash to do it, then I will try and help them out but I never got any of that. Unfortunately, the brakes that are on the car cost me about as much as the kits that are available allready. Mostly due to the fact that the hubs had to be cut and machined to except the aftermarket caliper. I wanted to run a 15" wheel but at the same time reduce brake fade to barley anything and I achieved that with great results. Not only did they perform well, they saved a good bit of weight.
