hi, ive been visiting this site for awhile and just signed up lol ive had an mx-3 for about 2 years now and love it, its a great car, ive been tinkering and messing with it for awhile and i have stumbled upon a few problems that i cannot solve.
1. i have another mx-3 a 92 1.6 SOHC AT, and ive been told to swap the motors ill have to change the crankshafts because my car has a MT, is this true?
2. im wondering which is better for a hp boost, ive been looking at the GUDE racing kit, or should i just turbo it, cuz ive heard the 1.6 sohc take kindly to forced induction.
3. does anybody know where to find forged pistons for the 1.6 SOHC? i cant find them anywhere.
sorry for asking so many questions, but i figured you guys would know
thanks
Connor
I need advice, and alot of it
- Ryan
Re: I need advice, and alot of it
The crankshaft thing is bulls---. I've done it myself more than once.
The flywheels use the same bolt pattern between auto and manual flywheels.
Most people looking for REAL power in the 4 bangers swap to the 1.8L BP, and boos that. the SOHC has ZERO aftermarket support, and as you already found.
A few people boosted the SOHC, but its hard, and expensive.
Yes, the 1.8L BP bolts right in, etc.
and pistons on these are never the weak point. Its always the transmission, or rods. I've seen a few KL pistons burn, but thats freak.
The engine is the same regardless of the transmission installed. Your ATX engine will bolt up to an MTX tranny just fine. The important thing is that the MTX uses a flywheel, where your ATX has a flex plate so when you remove the MTX from the donor car you have to take the flywheel and clutch as well...which are bolted to the crankshaft...and put them in place of the flex plate that you currently have. Just unbolt the flex plate and bolt on the flywheel. Probably best to have it resurfaced and replace the clutch while you have it all apart.
I'm not extremely familiar with the 1.6L SOHC and performance questions. Someone else is probably better for that question.
The 1.6L Miata used the same block as you and there are lots of piston options for that engine. Go to http://www.importperformanceparts.net/" onclick="window.open(this.href);return false; and click on Mazda-->scroll down to pistons and there are several manufacturers listed. You can use pistons for any 1.6L Mazda application. Protege, 323, Miata, SOHC, DOHC...doesn't matter. This gives you a range of compression ratios to choose from.
Ryan's right though...if you want more power swap in a BP.
I am also for swapping in a BP. Main reason is the support for the BP.. you can find lots of aftermarket support for it!
Awesome thanks guys
my winter swap shall begin then
ive looked at the BP before, and in fact almost bought one lol im just not sure if i want to take on the swap, no matter what im droppin the other 1.6 in there cuz mines bout shot.
is that bp swap terrible?
thanks for advice, i appreciate it.
btw
WOW that site is amazing!!! why havent i stumbled upon this before lol
Nah the BP swap isn't terrible lol.
You going to use your stock transmission? If so it makes it even easier![Very Happy :D](./images/smilies/icon_biggrin.gif)
the gearing on my tranny is low on the 1.6l already, i cant imagine how quick id go through the gears with more power lol
im gonna research this a wee bit
see if its feesible for me
