Hello!
I am completely new on mazda world and in this forum.
I have recently bought a 1.6 16v with a rough idle...
I have been trying to test my car but the pins in the diagnostic box are not labeled so i´ve been searching and found this http://www.youtube.com/watch?v=IU4uOHatUR0 video. Are these the correct pins that i have to use?
In this case my CEL doesnt light at all (neither when i put the key in on mode), is that correct.
regards.
Pd. Apart from this what specific tools are used to remove the TB?
Diagnostic box - CEL wich pins are used?
- Ryan
Re: Diagnostic box - CEL wich pins are used?
Where are you located?
I am from Spain (europe)
Does the pins depends on where the car has been made?
- Ryan
I don't know, thats why I didn't really want to answer, hoping one of our UK members would.
In NA, we use TEN and GND if your car is pre OBDII (95/96 ish) but OBDII might have started earlier in the UK... idk..
Ah ok thanks anyway
The problem is: the pins in my diagnostic box are not labelled...
I can't say for you guys in Spain, but over here in the US those are the correct pins to use.
