FS Hub Spacer for aftermarket steering wheel
lstpier
Post by lstpier »
Here you go: 1.7" thick spacer that mounts between the hub adaptor and aftermarket steering wheels. Provides the much needed spacing for your knuckles to clear the wiper/turn signal arm every time you turn the wheel. Comes with the hardware, only 6 holes to make on your adapter and you'll be ready to go. Will fit all wheels with 6x 70mm center to center wheel hub.
<img src="http://www.mx3gsr.freeservers.com/pics/IM001934.jpg" alt=" - " />
Steeb
Re: FS Hub Spacer for aftermarket steering wheel
Post by Steeb »
this will not bolt directly to a momo hub kit rite?
lstpier
Post by lstpier »
Momo/Sparco and other makes with 70mm center to center will bolt right on the hub spacer. On the Hub adapter side you need to drill 6 holes (using the hub spacer as a template) to mount the spacer to it with the supplied hardware.
