Millenia S injectors for turbo ze 92 gs
Do I just get the replacement millenia injector seals or the ze injector seals?
- solo_ryder
Re: Millenia S injectors for turbo ze 92 gs
Same dimension injector so shouldnt matter. Just get the millenia ones anyways to be safe..
- johnmx3ze
there the same... no difference!
I used a K8 injector seal on my ZE...works just fine as well
93 mx-3 GS (KLZE w/kl01 cams, XTD stage 3 clutch, Outlaw intake/throttle body spacers, throttle body coolant delete, headers, full 2.5" exhaust w/resonator and 40 series flowmaster, filled engine mounts)
99 silverado
99 silverado
Well thanks boys, I didn't wanna look like a fool with my pants on the ground.
Where are you putting these injectors!?DiaMagus wrote:Well thanks boys, I didn't wanna look like a fool with my pants on the ground.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
- Ryan
Lol....
I'm more concerned about where he's putting those rings
Dude I'll post pics- ! Thought you'd sick bastages would like that
Im in mid boost of my mx3 blah I ran it at the track the other night
best time 14.8 at 94.6 mph not bad not bad
I was just quoting american idols stupidest performance ever.
THAN YOU GUYS HAD TO COME IN WITH THE JOKES!!!
hey its getting a little weird in here!
- Inodoro Pereyra
Just in case you're not aware of it, there are 2 different kinds of Millenia S injectors. Up to '99 injectors are 280 cc/min, and '99 and later are 305 cc/min.
Diogenes of Sinope.
Diogenes of Sinope.
So I take it you are going to be using megasquirt to run those right?
-hec
They are still in the rails and the plug says 2007 on it so Im guessing its off a 2007?
hgallegos915 wrote:So I take it you are going to be using megasquirt to run those right?
Eventually, Track is closed for the rest of the year since its approaching fall here in Minnesota so yea- I was just going to toss them in with the cosmos racing afpr I bought and 255... Can't do that? I'm totally in the dark without a flashlight on this - !
Pants on ground-
I was runnign cosmos afpr, fmu and millenia injectors. Its way to rich, fouled spark plugs and messed up my wideband sensor.
-hec
