Oh god. So Window switch questions now- ;_;
Ok. So I replaced the window switch because it was broken, also the passenger window actuator. Now then! I know that its a 95+ switch so I have to do the mod so the passenger can open the window... what my issue is at the moment. I can roll the driver side window up. However it will not roll down. I took the switch apart and it looks good. Does anyone have an experienced opinion of weather this is my switch. Or the actual actuator. I just replaced the passenger side- Like I say it rolls up but now down. Seems to me the switch may be finicky. Thanks guys I hope this was informative. I know about the mod to fix so passenger can open the window . Like I say my drivers side will roll up and not down. Thanks
Re: Oh god. So Window switch questions now- ;_;
Check to see if the down wire has continuity
Thanks bro~ It does- Voltage to one side with switch depressed for upward motion. Voltage to the opposite side (Of the plug that connects to actuator) when switch is depressed for downward motion. Looks like I'm dealing with a bad window motor.
take the circuit board out of the plastic casing and try to manually move the spring loaded switches manually with a small screw driver or something. often times the plastic switch is not traveling far enough to engage it. i would try that before ruling anything out
