I would like to buy a manual seatbelt conversion kit for a 1993 mazda mx3.
I am also looking for the center console for the said car.
I am located in the USA.
thanks
WTB - Manual Seatbelt Kit for 93 MX3
Knowledge Is Power ; Keep Cracking
Re: WTB - Manual Seatbelt Kit for 93 MX3
When I did my conversion I went to a pull it yourself junk yard and used probe seat belts, their is a spot in the frame they thread into, the only modification needed is drilling into the side for the bolt to go into, and also to put a notch side piece. I spent $15 for the pair.
93 GS/SE
- PATDIESEL
hmmm, good idea Mikey. You can also get all the pieces required from a Canadian. They only got manual belts in the MX's up there.
Thanks,
I will definitely check it out.
Still looking? I have a set off a Eunos I could send you.
Owner of the UK MX3 site.
