ukrman - 92 MX-3 GS
Ukrman
Re: ukrman - 92 MX-3 GS
Post by Ukrman »
but check engine light comes on... which should not be related to idle control. I just feel like it runs too lean...
92 Mazda MX3 GS
http://www.cardomain.com/id/ukrman" onclick="window.open(this.href);return false; - cardomain page
viewtopic.php?f=46&t=66481 - worklog
viewtopic.php?f=37&t=72099 - feedback
viewtopic.php?f=2&t=71757 - stuff for sale
http://s2.metaldamage.com/c.php?uid=159229" onclick="window.open(this.href);return false; - biggest waste of time
Ryan
Post by Ryan »
what code? could be any sensor.
Ukrman
Post by Ukrman »
i haven't checked the codes.... i'm gonna play with it tomorrow and see if I can figure it out.
92 Mazda MX3 GS
nightfire
Post by nightfire »
If you think it's running too lean, try pulling the vacuum hose from the fuel pressure regulator. That'll raise the pressure to (iirc) 45PSI, which will deliver more fuel. If it idles better in that state, that's probably the problem.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
Ukrman
Post by Ukrman »
After installing the steering wheel, it was a little to close to the "turn signal handle" so I got one inch spacer... wokred out awesome
Before...
After...
Another Shot
92 Mazda MX3 GS
Ukrman
Post by Ukrman »
so i got some more free time this weekend, so decided to install my new suspension
Parts:
Tokico Shocks
Eibach Springs
KYB Strut Mounts
KYB Strut Boots
Cork Sport Front / Rear Strut Bars
So this is my car before:
and after:
heres the front strut bar:
I'm still working on the rear strut bar, since I have to modify a couple parts to make sure everything fits nicely.
92 Mazda MX3 GS
Ukrman
Post by Ukrman »
So finished working on the rear strut bar
had to modify the rear seatbelt base
this is the trim without any modifications
plastic trimmed
strut bar tried on to make sure I have enogh clearance
finished product
92 Mazda MX3 GS
nightfire
Post by nightfire »
Nice work. All of your mods are very clean. :welder:
Looks like we've got an identical suspension setup now. What do you think of it?
- Gord
Ukrman
Post by Ukrman »
thanks... I had this same set up (minus the strut bars) on my 1st mx3 and it was awesome. I still have to do my wheel alighment, so havent driven it too much but so far it feels great.
92 Mazda MX3 GS
nightfire
Post by nightfire »
I am jealous of your nice roads. :crying:
- Gord
Ukrman
Post by Ukrman »
nightfire wrote:I am jealous of your nice roads. :crying:
haha theres enough crappy roads around here
92 Mazda MX3 GS
Ukrman
Post by Ukrman »
Installed the whiteine rear anti-sway bar. The difficulat part was taking off the rear sway bar links, they were all rusted and seized, so I ended up just cutting them off and getting new ones. Luckily, I checked amazon and they must have had a price mistakes, so I bought two links for $16 and when I chcekd the following day, they were back to $64 each.
Just trying to put some "liquid wrench" to losen up the bolts, but did not help
Had to cut off the rear link :)
New rear sway bar links
Whiteline compared to the stock sway bar
Another shot of comparison
Links in place
Finishing up the install
Finished (ps first time I installed it with the sticker upsidedown, so I just reinstalled it to be the correct side up lol)
So this week I will get wheel alighment and then do some testing :)
92 Mazda MX3 GS
nightfire
Post by nightfire »
Congrats. I think you'll love it. :)
I just noticed though - are your jackstands under the trailing arms? If so - be careful. I bent mine quite badly by using them that way. Some say they're strong enough, but I know for fact that they aren't. They're hollow, not solid.
That said, they're only $60 at the dealer to replace. But still.
- Gord
Ukrman
Post by Ukrman »
hmm i think its just the pic.... pretty sure it wasn't on the trailing arm lol..... but then again i jacked it up a couple times so maybe in a hurry i got one lol
but thanks for looking out
92 Mazda MX3 GS
Ukrman
Post by Ukrman »
Haven't posted here in awhile... not much has been happening to the MX-3, just don't have time :(
So I had some free time and decided to clean it up a little bit. The paint was getting very dull and pinkish looking. So I got some Meguiar’s Ultimate Compound and Meguiar’s NXT Generation Tech Wax 2.0. First I used the compound, it took forever to get all the little scratches and the oxidation out. After that I went over the whole thing with wax, and it came out awesome. I love the fact that there's no clear coat, so you can really make it shine. Some of the areas that were just not recoverable were the mirrors and the spoiler a little bit. Other than that it came out looking great for 18 year old paint job.
Here's some pictures to just compare the paint before and after using the compound
And here's some pictures after using the compound and then waxing. The camera does not do it justice.
92 Mazda MX3 GS
