i have spare tire, stock jack, stock radio, sway bar rear, you just pay shipping or come pick up
(i am in dallas, texas)
mx3 stuff give away
- papa roached
Re: mx3 stuff give away
what about that screw thing you screw into the holder for the jack so it dont move or fall out?
i need the tape deck. you have mail.
Sent you an email for the rear sway bar
