B6t swap wont start????
- psycotickustomz
Ok im needing some serious help on this one. I bought a running 93 capri xr2 with a 114,xxx miles on it, rebuilt it and swapped it into my 93 mx3. I have fuel and spark but the car wont start??? The clock on the dash flashes also? If anybody cant help me out please let me know by e-mailing me at psycotickustomz@yahoo.com" onclick="window.open(this.href);return false; or calling me at 419-788-3772 i appriciate any and all help.
- psycotickustomz
Re: B6t swap wont start????
I'm racking my brain here, isn't there anybody out there that can help me? I've looked in the FAQs section as well as searched everywhere and found nothing. Please help me.
- Ryan
I have no experience with that exact swap, but I can ask the typical questions.
Which harness/ECM are you using? Is your ECM grounded properly? Did you fiddle with the timing? Did you pull the codes? Do you have spark? Fuel? is the airflow meter (and everything else?) plugged in? any obvious vacuum leaks?
- psycotickustomz
I am using the mx3 harness with required wiring lengthend. I have double and triple checked to make sure that all of the sensors are hooked up. I have the capri fuel pump installed and am getting fuel at the motor and I'm getting spark but its not firing. I think that the injectors aren't firing, but that still doesn't explain why the clock is flashing.
- Ryan
what about the other things? Check fuses too.
Are the plugs getting wet? If it sparks, plugs get wet, and the airflow meter is working, only proportions are left. Leaks. Injectors stuck open, vac leaks, and timing.
Or your ECM is baked? electronics are the only thing that cause weird issues.
From your alternator to the battery there is a ground wire 6" long with a
pre soldered loop on it. If its not properly grounded there it can cause the
car to not start and the clock to not hold time.
1994 MX-3 RS
B6 goodies for sale:
viewtopic.php?f=2&t=66333
- Ryan
Clock won't hold time if the ECM isn't grounded, too.
- psycotickustomz
The pcm is grounded, and the clock is keeping time but its just keeps flashing. I'm having a feeling that the injectors aren't firing correctly b/c the plugs aren't soaked in fuel but they do smell like fuel. Anybody got any ideas about what could be wrong? Maybe the injectors aren't wired correctly?
- RS_OBD'oh_2
+1
Ground/batt/electrical issue
- psycotickustomz
ok so i pulled the CEL sodes from my car and got 3, 5, 8, 9, and 11. I have searched and cant seem to find out what they all mean. I even went to autozone but the book they have didnt match any of the codes to my mx. please help.
- RS_OBD'oh_2
all the codes are posted on these pages. Search
- psycotickustomz
Ok so I have been able to clear all of the codes except code 3 and from searching the forum I have found that the car should still run with that code present, is that true? Or will code 3 keep the car from starting?
