Im stuck in NY my alarm was activated last night. now today the clicker wont deactivated it.
how can i disarm my alarm plz some one help i have to get back to
Pa monday for school.
My Alarm wont turn off!!!! URGENTTTTTTTTTTTTTTTTTTTTTTTT
- mitmaks
Re: My Alarm wont turn off!!!! URGENTTTTTTTTTTTTTTTTTTTTTTTT
your remote has a dead battery?
just changed the battery..any other suggestions?
- Dali
is the car battery almost dead? what brand of alarm? will the car start with the alarm going off? unhook the car battery and let it sit for a minute then hook back up, this might reset the alarm depending on the brand. if that does not work....then see if the car will start and run with the alarm going off, if it does unhook the siren for now. depending on brand again your lights may still flash. all depending on the brand of alarm, what options it has and how it was hooked up.
1993 White gs klze.
i just brough another battery just in case to see if it was the clicker... mo luck
The car will not start while alarm is going off.
i will unhook the battery as of right now and see if it resets everything.
thanks for the help///
if unhooking doesnt work w hat could i do next?>
fixed for now!!!.. thanks for your help i really appreciate it.
what do you feel caused the problem?
- Dali
depending on the brand....brain fart, battery almost dead, sensor stuck in a open loop. it could be one of many things, what brand is it?
1993 White gs klze.
- _-Night-Shade-_
Probably the car battery died from the alarm being on too long and then didn't have enough juice to depower the alarm.
One time on my old MX-3 I left the headlights on all day by accident (I was in a hurry) and the battery drained and the alarm went off (not sure why, even my current one will do it if you disconnect & reconnect the battery, maybe security feature in case someone tries to cut the power?), and I had to unlock the door manually and turn it off cause there wasn't enough juice for the keyless to work.
yea possibly the batter..i used my meter and got 12.6v ..but i wanted to kno the cca's so i used the microvat and it showed 225 cca's so..plus the battery has bn in the car from the previous owner for bout 5 yrs..so i will buy new one this week.
thanks again guys ima check the brand of the alarm today and let ya kno.
