tach signal wire
blackknight
tach signal wire
I was wondering on the k8 distributor what wire gives you that tach signal???
- Ryan
Re: tach signal wire
I believe it is the centre pin on the 3 wire plug. Depends on the year of car, though, I believe.
93
on a 93 it is the center one on the 3 pin
93 mx-3 with a klde swap. still working on
94 cobra svt. mostly stock.
08 ninja. 1 wheel fun. lol
Answers given here are absolutely correct. Check out the V6 FAQ HEI mod info here for this and more.
blackknight
Thanks a lot for the info I was looking for it to see if that would give me the tach signal that my ms is asking for. Found out that is not the reason but thank you for the help.
