tranny fluid.
- SpatialTerror
tranny fluid.
how much do i put in. i am using the tranny off the k8 on my klze.
and i cant figure out how much and where to fill it.
93 GS-R with crank pulley racing clutch and flywheel, magnaflow cat back exhaust, short ram air, 12" rockford fosgate p2 subs, on a amp 500rms, jvc touch screen deck.work log --->http://mx-3.com/phpBB3/viewtopic.php?f=46&t=75217
92 RS with lowering springs, and body kit.
SpatialTerror
SpatialTerror
- _-Night-Shade-_
Re: tranny fluid.
You did a KLZE swap and you don't even know something as basic as this?
- Dragyn Vyrus
Re: tranny fluid.
its a 23mm bolt on the front of the tranny, fill it till gear oil starts to come out then put the plug back in. im assuming you have a 5speed
93 MX-3 ZE-GS - Sold
95 MX-3 RS - Bone stock winter car.
92 JDM turbo MR2 - SSQV, Cusco strut tower bar, ATS intercooler kit, Berk Exhuast, HKS EVC-S
- SpatialTerror
Re: tranny fluid.
ok i found it. and yes it is a 5 speed. And i just fill it till it is level with the bottom of the check hole right?
SpatialTerror
SpatialTerror
- JWMX3
Re: tranny fluid.
yes, and use a GL-4 gear oil.
- SpatialTerror
Re: tranny fluid.
and how much do i fill it with?
SpatialTerror
SpatialTerror
- mitmaks
Re: tranny fluid.
According to shop manual its just over 3 qts, I just bought some synthetic Mobil 1 75w90, which I'm changing soon.
- SpatialTerror
Re: tranny fluid.
dude it sucks. it took forever and i even had a oil pump
SpatialTerror
SpatialTerror
- mitmaks
Re: tranny fluid.
You pumped it out? You didn't have to there's drain bolt and drain bolt.SpatialTerror wrote:dude it sucks. it took forever and i even had a oil pump
http://www.mx-3.com/manuals/showimg.php ... J2-003.gif" onclick="window.open(this.href);return false;
http://www.mx-3.com/manuals/showimg.php ... J2-008.gif" onclick="window.open(this.href);return false;
- SpatialTerror
Re: tranny fluid.
no i pumped it in. it took like an hour that oil is thick
SpatialTerror
SpatialTerror
- JWMX3
Re: tranny fluid.
wow, i use a funnel with the long flexible neck on it. takes 5 minutes to pour it in. the transfer pumps are good but normally only use those where there is no room to pour from above. ie. rwd trannys like my b3000
Re: tranny fluid.
was the drain bolt on the bottom of the transmission rounded off? If not you wasted alot of time & effort lol.SpatialTerror wrote:no i pumped it in. it took like an hour that oil is thick
1 mx6 88 LX auto 2.2l 4cyl
2 mx6 93 LS saved from junkyard SOLD
3 Mx6 96 M edition blow a ze part it
4 Mx6 96 gold LS paint n lights auto SOLD
5 mx6 red fresh paint clean, sold
1 mx3 92rs sohc auto rota c8s h&r
2 mx3 93 gsze bought w/ mods
3 mx3 93 GSze mtx swp act stg3 str8 nek im eibach kl36
4 mx3 GS SOLD-
6 mx3 white gs jdm swap'd SOLD
*5th mx3 blk GS clean title modded DD*
1 PGT 97 blk, garaged clean sold
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
- SpatialTerror
Re: tranny fluid.
yea. it was. if i had messed up i would grinded my tranny all to s--- by now
SpatialTerror
SpatialTerror
Re: tranny fluid.
I typically just use a few feet of clear hose from a hardware store and a funnel. Can do it from either wheel well or from engine bay. Doesn't take too long. Refilling the differential on my RX-7 - now that was a PITA. Wish I had a pump.
Re: tranny fluid.
I use two bottles of lucaus 80-90 and one bottle of lucaus auto trans fix comes to 3 quarts makes it really thick and so far my transmissins have been takeing the abuse of 300hp and 330tq on a stock g-series trans the gears take it not the diffs tho. Only draw back is in the winter it is so thick it dam near stalls the car when you let the clutch out and its hard to shift till fluid warms up. But I dont drive that car once its snows or is below 40 deg. So no big deal for me.
93 Mazda Mx-3 rs,BP-T swap,22psi,custom fmic,Custom 2-1/2 downpipe with external dump,2-1/2in downpipe back exhaust,Tuned with Megasquirt on E85,Mazda protege G-series transmission,GS rear disk brake swap,H&R lowering springs,corksport front/rear strut tower brace. Dynoed at 300hp and 330tq Mustang dyno, 8.5@87mph 1/8mile http://www.cardomain.com/ride/3139490" onclick="window.open(this.href);return false;
93 Mazda Mx-3 GS,BP swap. Daily driver
