[WTB] Climate Control Slider Caps??
- jkbreazeale
Yep! That is what I am looking for. I have been through all the junkyards and come up with close matches but it seems that the climate control setup is unique for 95 for the 93 setup has bigger knobs. If anybody has a pair of these for a reasonable price then I will definitely buy them. I need them for a 1995 Mazda MX-3.
Thanks,
Keith
Thanks,
Keith
Last edited by jkbreazeale on December 29th, 2009, 4:54 pm, edited 1 time in total.
1993 MX-3 RS (my project car) http://www.cardomain.com/ride/3815854 <- Check out my Cardomain!
1995 MX-3 RS (wife's project car)
Re: Climate Control Slider Caps??
PM tmac4t4 maybe he'll sell the ones off the spare controller I gave him.
- umcamara
'95+ doesn't necessarily have the logic climate control. My '96 had the manual slider controls until I swapped in the logic one. You'll wanna specify either cable type or logic type, not year.
- jkbreazeale
I'm not looking at replacing the whole unit just trying to find the black caps that fit on the slider.
- umcamara
I realize that. But the point is, if you specify that you want the caps off either the cable type or the logic type climate control, then you'll get the right caps. Saying what year vehicle you want them off of won't guarantee you anything.jkbreazeale wrote:I'm not looking at replacing the whole unit just trying to find the black caps that fit on the slider.
- jkbreazeale
Ok so I guess all that I need to do is take out he climate control and see if it is cable controlled. If it just has a wiring harness that means it's logic correct?
- umcamara
They'll all have a wiring harness. The difference is that the logic controller uses digital push buttons to change the airflow from floor, vents, etc, whereas the cable type uses slides to change the airflow mode and you can actually feel a wire being pushed and pulled inside of the cable as you move the slider.jkbreazeale wrote:Ok so I guess all that I need to do is take out he climate control and see if it is cable controlled. If it just has a wiring harness that means it's logic correct?
No need to remove the climate control. There are only two types, and it's pretty straight-forward to tell the difference between the two.
- jkbreazeale
Ok then it is logic based. You saved me a teardown
- jkbreazeale
Bump!
- MrMazda92
jkbreazeale wrote:Yep! That is what I am looking for. I have been through all the junkyards and come up with close matches but it seems that the climate control setup is unique for 95 for the 93 setup has bigger knobs. If anybody has a pair of these for a reasonable price then I will definitely buy them. I need them for a 1995 Mazda MX-3.
Thanks,
Keith
You forgot the [WTB]!!
Ban he!!! :O
- jkbreazeale
[WTB]Climate Control Slider Caps??
No! Do not ban me! I'm sorry!
- umcamara
Re: [WTB]Climate Control Slider Caps??
Say 14 hail mary's, and bow to the WTB gods.jkbreazeale wrote:No! Do not ban me! I'm sorry!
