....Not sure yet , Have not looked into it yet, still have a long way to go on getting everything done...What did you end up using/doing?Limegreen mx-3 wrote:what are u going to do about the bp's v-belt and poly v belt pulley setup..
i hated that shyt and switch it out....
UPDATE with more PICTURES
1. Assembled the shocks/coil-over sleeves; ZX-2/GC's. Also brand new strut top mounts (accidentally threw away the old ones )
2. Put on my "temp" tail lights (smoked altezzas) until I finish my rx-7/kouki lights
3.Well, after 9 years, the supra-style wing has come off .....
Will be using a "temp" USA-spec GS wing, until I am ready for paint, and then the CDN-spec wrap around will go on.
4.B&M short-throw-shifter as well as all SRD bushings installed. Also anti-drop bracket.
5. 2 more shots of the engine bay finished paint and cleaned:
6.Full under-body cleaned and undercoated
7.Control arms, spindles and suspension back together. Wytbishop front sway bar endlinks installed.
All new rotors, pad, and calipers will be going on
AND...this picture probably gives it away, with the hacked CV axle poking out, you may have guessed it.................................................................................................
MOTOR and TRANS is IN
8.
9.
10.
11.
More to come...
