Hello, i recently just bought a MX3(1993 GS) and when i added my sub in, I blew the 2 left speakers
so i was lookin for new ones, but i would also like to know the size of the front and the back speakers
If anyone could help that would b awesome!
thanks
WTB: front/ rear speakers
If you can't race it, then it ain't worth havin
xXx_OTEP_xXx
georgechicken
Re: WTB: front/ rear speakers
Nope, not 5" speakers, sorry. They're an oversized 6.5" speaker. You'll be hard pressed to find an exact fit. I had to make an adapting piece to fit my front 6.5" speakers. In the rear, I have Lanzar midbass woofers that are almost perfect fit. The bolt pattern is right, but the round frame of the speaker interferes with the cover that it bolts into. I simply notched the inner side of the cover to fit them . They're a pain to find because the front ones are a VERY shallow mount depth (most speakers' magnets interfere with the window), with a 3bolt (triangular) pattern on the oversized 6.5" size. The rear are even tougher. They need to be bottom mount (bolts go through the backside of the speaker frame) speakers, also an oversize 6.5" 3bolt fitment. There are a few out here, but they're few and far between. With a bit of creativity, you can make most any speaker fit though. Good luck!
--Maybe the Hippopotamus was just a really cool Apotamus.--
trumper_82072
Do you want stock speakers? I will be upgrading my system. Let me know mine all work.
