If you get a Too many connections error when you try to connect to the mysqld server, this means that all available connections are in use by other clients.
The number of connections allowed is controlled by the max_connections system variable. Beginning with MySQL 5.1.15, its default value is 151 to improve performance when MySQL is used with the Apache Web server. (Previously, the default was 100.) If you need to support more connections, you should set a larger value for this variable.
Sounds easy if this is what it is! Never touched forum code though, so what would I know
AZ-3 1498cc Turbo! EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt Mx-3 2.5 V6 Turbo 291 BHP 251 lbft @ 8psi - Retired due to rust and back at uni View Worklog
Yeah. I'm inclined to report that I haven't had any issues in the last few days, but I'm afraid if I do it the whole internet is gonna come crashing down.
I havent gotten it.. I will make a screen cap and post it if it happens again.
-hec
Its sad how addicted we are.
NOOO!!!! I CANNOT ACCESS THE FORUM TO ENGAGE IN WONDEROUS BRINGING OF MX3 KNOWLEDGE!! NOOOO
2003 Forester Xti - EJ20K swapped. Feedback
