Hey, looking to see if anyone knows the size of the oil pressure hole/threads on the B6 head between the disty and the TB.
I've tried 10mm and 1/8... I figure it should be metric. The hex plug (currently filling the hole in the head) seems to screw into the 10mm and 1/8 but the threads dont match with the hole. - if that makes any sense.
I'm guessing it's going to be 8 or 9mm... but confirmation would be great. Thanx.
On a side note.. if anyone has pics of the water lines to turbo (from the t-body or anything else would be a big help too) - I figure I'll have to cut the lines and just place a "T" in.
Help with oil pressure fitting
- RS_OBD'oh_2
Re: Help with oil pressure fitting
theres a hole for that on the head i just used the oil warning light hole next to filter can you post pic of where you are talking about plz and the hole size is standard thread size for oil pressure fitings i dont remember exact size off top of my head but you cah go to parts store and have them pull a stock sensor and use it to find what your looking for
LIFE IS A SEXUALLY TRANSMITED, TERMINAL, DESIESE. AND WE ALL SUFFER FROM IT.
- RS_OBD'oh_2
Resolved a month ago.
