Oil pan Question.....
I couldnt remember is our oil pan alum. or steel?
Re: Oil pan Question.....
im pretty sure it aint aluminum
See is a refridgerator magnet (or any magnet for that matter) will stick to it. I'm pretty sure it's steel but def not aluminum. It'd be too soft of a metal being so close to the road. If it were aluminum, one scrape and you'd leave a lot of your pan on the road.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
def not alum.mazdamx3freak wrote:I couldnt remember is our oil pan alum. or steel?
I think its some sort of brassmetal. When I was sanding it down to weld, it was a brass material. They had to use special weld to get the bung in there.
My magnetic oil pan plug sticks to it tho.
-hec
It rusts, so I would say steel
