Eaton M45
http://www.capa.com.au/eaton_m45data.htm" onclick="window.open(this.href);return false;
5psi takes ~5-10hp
10psi takes ~10-20hp
supercharged 1.6 sohc
Re: supercharged 1.6 sohc
how do you figure?projectzemx3 wrote:however the post about the engine only having 88 horse stock so if you added low boost for safety, would only bring it up to 130 made me laugh so hard.
the best power mod you can make out of your b6 powered mx3, is to remove the b6.
Source a turbo manifold, small framed t3 (.42 or .60/.48), 14b, something maybe a bit larger, and a decent fuel setup/method. (safc and bp26 or megasquirt) run moderate boost and make 200 fwhp.
sure boost wont come on till 2500 rpms, but who drives their car around below 2500 rpms.
I look at it this way with how short our trannys are geared and my hybrid turbo, boost is a gear away.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
There is really no point in supercharging a 1.6 sohc. Sohc is an automatic swap, no questions asked. Then save some money up and turbo that sonuvagun!!! ![Shrug :shrug:](./images/smilies/shrug.gif)
