Well ever since i bought the car the camber has been off and i thought it was the strut so i changed it its a little better but still not good it still pulls to the left. i tried a camber kit bolt thing and it didnt work. im just wondering what to do i have pics of the camber messed up so u guys can tell me what u think maybe wrong.
http://i378.photobucket.com/albums/oo22 ... CN2042.jpg
http://i378.photobucket.com/albums/oo22 ... CN2043.jpg
http://i378.photobucket.com/albums/oo22 ... CN2041.jpg
93 mx3 1.6L camber is off after strut change
nnblackgt
95 Probe GT "Dragonfly" KLDE - Sold , 94 Probe GT "Komugi" 5spd KLZE - Totaled , 93 MX3 "Chibi" B6 SOHC - Soon KL swap ^_^
Probetalk Forums Member and Otaku (Virginia Probe Owners Club)
Re: 93 mx3 1.6L camber is off after strut change
Is it just that one wheel? I would say it could possibly be a bent spindle...although I'd be surprised if you could bend one without breaking it.
I would start looking in the junk yard for a complete spindle and hub for it and just swap it on and see how that looks. Won't be too expensive and couldn't be in any worse condition that what you have.
- _-Night-Shade-_
It looks like you just need to get it aligned...
nnblackgt
i took it up to kramer tire and they tried to align it before i changed the strut and said they could because they dont know how to adjust the camber its sitting at -3.8 and they told me they arnt gonna mess with it they arnt a real alignment specializing shop its a multi shop that does tires, struts, mufflers ect and the guys there acted like they didnt know what to do._-Night-Shade-_ wrote:It looks like you just need to get it aligned...
was the camber kit bolt thing just a bolt? if so that should be more than enough to correct the camber! You just replace the top bolt in the strut with the camber bolt and there's quite a range of adjustment...nnblackgt wrote: i tried a camber kit bolt thing and it didnt work.
although it doesn't explain the actual root cause (maybe wytbishop is on to something in his diagnosis)
nnblackgt
yea its a bolt with a tab on it i put it on there and tightened it didnt move at all unless i didnt do it right. but ill probaly just go to the junkyard and get a whole new suspension on the drivers rear side like wytbishop said.Mooneggs wrote:was the camber kit bolt thing just a bolt? if so that should be more than enough to correct the camber! You just replace the top bolt in the strut with the camber bolt and there's quite a range of adjustment...nnblackgt wrote: i tried a camber kit bolt thing and it didnt work.
