is the whiteline sway bar for me??
jamesmx3
Post by jamesmx3 »
I have zx2 gas struts and -45mm springs, the ride can be harsh on cr@p roads, when i hit pot holes ect, will the sway bar make it worse or just keep it more stable round corners??
1997 1.6 16v DOHC uk spec gs, 17" wolfrace triad, 2.0l probe s/s header magnaflow high flow cat, powerflow custom catback, CAI, zx2 struts w/ -40mm lesjofors springs
http://www.uk-mx3.com" onclick="window.open(this.href);return false;
yence
Re: is the whiteline sway bar for me??
Post by yence »
The whiteline rear swaybar will reduce bodyroll and understeer, all without comprimising the ride quality. Sounds like it's for you 8)
1995 noble green MX-3 RS (sold)
1994 clear white MX-3 GS (r.i.p.)
1987 white RX-7 FC
1993 mighty grey MX-3 GS
96mx-3
Post by 96mx-3 »
is the 96 bar the same size as the whiteline ?
Flyer
Post by Flyer »
My 1996 swaybar measured 20.XXmm...don't remember if it was hollow or solid though...
jamesmx3
Post by jamesmx3 »
is that the difference with the whiteline one, that its solid so it should be stiffer?
yence
Post by yence »
If not mistaken, the whiteline is 22mm.
1987 white RX-7 FC
fowljesse
Post by fowljesse »
Yeah, the Whiteline is 22m, and solid. It made a difference on my car, and I have everything else done. I don't know about pothole resilience, though.
96mx-3
Post by 96mx-3 »
ok thanks. . i guess i miss read info somewhere..
