quick and easy compression testing
- ovendenk
the klze should be 210psi, the k8 should be 195psi, and the b6 should be 185psi. the limits of tolerance are +/- 10% for each cylinder and you have to make sure that there is not more than 30psi difference between any 2 cylinders.Billyd wrote:So what is true "good" compression? Anyone find out? Do they have that compression tool at AutoZone also? I'll have to check.
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
hgallegos915
Re: quick and easy compression testing
really? i got 180 all across the board :/ i had 190 like 1 year ago.
162 whp at the dyno.. hmm
its just a worn out ze i guess.
-hec
Re:
That does that do if it is?ovendenk wrote:make sure that there is not more than 30psi difference between any 2 cylinders.
probably just build up on the valves not letting them seal correctly....ovendenk wrote: should i be concerned with the 20psi difference between #2 and #1?
- Daveb
As far as I know a compreesion test s/b done with a warm engine, plugs out, to get optimum results. You might find that your psi difference between cylinders is less with a warm engine. sounds like good numbers to me anyways. Since you havent started your engine up, you may have a little more or less oil in some of your cylinders.
1994 GS 5 speed 1.8, fresh black paint, flowmaster muffler & Little smelly pine tree
1993 RS 5 speed SOHC with 89,000 original KMs! (rising fast though).
1994 RS 4 cyl auto- running parts car with 104,000 KMs
