I have a 92 mx3 with no trans fluid plug
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
92EmeraldDream
Post by 92EmeraldDream »
Is it just my difficulty of having to find it or is there another way to fix this problem?????
92' Mazda Mx31.6L Rs with catback exhaust,struttower brace currently disabled with some frnt end Damagehttp://element.searchpluswin.com/?cmd=s ... &rb=930734[URL=http://element.searchpluswin.com/? ... .jpg[/img]
[/url]
onlytrueromeo
Re: I have a 92 mx3 with no trans fluid plug
Post by onlytrueromeo »
LOL, um if theres no plug you have no fluid...thats bad. Don't drive the car until you get one...but how did you find this out? There is no way the car would have been driveable...unless you just misplaced it by accident.
92EmeraldDream
If i would have a better idea of locating the plug it would be helpful
[/url]
onlytrueromeo
Your best bet is to try Napa or Mazda. Napa will be cheaper but I dont know if they can order it for you. Seriously though, if you're missing the drain plug, don't drive it! I'm assuming you just bought this, or you just lost the plug - if you just bought it, make sure it drives because I can't stress to you enough that you really should not be driving it w/o fluid in there.
92EmeraldDream
I looked up the trans in the chilton's manual for Mazda Mx3, the only information that they provide for a 92 1.6L is that it is a G5M-R trans I dont know if this type is even equipped with a fill plug.
[/url]
marcdh
Post by marcdh »
I'm getting the feeling he's trying to physically find the drain plug, not buy the part. Check the workshop manuals on the main page.
F series:
http://mx-3.com/manuals/showimg.php?fil ... J1-007.gif
G series:
http://mx-3.com/manuals/showimg.php?fil ... J2-007.gif
View Worklog
2fazed
Post by 2fazed »
If I remember correctly, the sohc drain plug is behind the block next to the firewall. The speedo cable is connected to it. Theres one bolt that holds it on. On the V6, it's on the front side of the tranny. Seeable from under the car. Hope this helps.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
92EmeraldDream
AS I can see the plug must have some disguise to it,because when I check to see it...
I don't see anything.
There has got to be a picture that can provide a seen to help find it.
[/url]
92EmeraldDream wrote:AS I can see the plug must have some disguise to it,because when I check to see it...
use this picture to see where it is located when looking in the engine bay - it's labeled number 4 near the back of the tranny close to where the tranny meets the motor...
http://mx-3.com/manuals/showimg.php?fil ... J1-002.gif" onclick="window.open(this.href);return false;
it's not a normal bolt it's the speedo driven gear... use this link to see a pic of what you should be looking for
http://mx-3.com/manuals/showimg.php?fil ... J1-007.gif" onclick="window.open(this.href);return false;
92EmeraldDream
After i looked at the manual it does not seem like there are to many other ways to see how the operation is performed, Now it is just the decision of if I should replace the whole part when changing the gear oil or reuse the same hardware.
Just curious if this is a picture of the transmission of the 4cyl. or the 6cyl.? Are the trans. the same for this year?
[/url]
Return to “Transmissions”
