Differences between 1995 and 1996 rear calipers
nightfire
Post by nightfire »
Brake gurus,
I'm about to order new rear calipers from rockauto.com. It looks like they have different parts listed for the '95 and the 96'.
Does anyone know if there are any differences between the two I need to know about before I order?
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
projectzemx3
Re: Differences between 1995 and 1996 rear calipers
Post by projectzemx3 »
i know that where i work they had two different part numbers for rear calipers
it was because one was loaded and the other was semi-loaded
NEED PARTS INSTALLED? PM ME!
Loaded and semi loaded? Are we talking the brakes or the mechanics. I need new rears too so this is news to me, sh*t I just bought some too.
projectzemx3
i think loaded means it comes with new slider pins, codder pins, brake pads and the caliper comes greased. semi loaded i believe is just a caliper thats greased.
So loaded has nothing to do with compatability, good. So now why can't we use 95's on a 96. I await Nitefires response. :D
nightfire
Post by nightfire »
Ahh.. ok that makes sense. Well, I need everything so I suppose I'll just order the loaded kit.
- Gord
