Mx3Kid's 93' Mx3 Project (Pics inside)
Re: Mx3Kid's 93' Mx3 Project (Pics inside)
If I used lowering springs with stock shocks wouldn't that blow them out?
CF Hood, Kenwood everything, 2.25 catback exhaust, H&R Springs, F&B Strut bars
My worklog: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=68856" onclick="window.open(this.href);return false;
Good afternoon from the biggest Douch around;D
Depends how low. The biggest problem with the DropZone's is that they are so low...or can be...and so stiff that the shock winds up in the compressed position pretty much forever. They blow up pretty fast. If you only lower it an inch and a half or so and the spring rate actually allows some travel, they will last a good while.
not if you buy new stock struts from somewhere. they dont need to be fancy, lots of people use kyb.
NEED PARTS INSTALLED? PM ME!
![Image](http://i453.photobucket.com/albums/qq253/projectzemx3/avator2.jpg)
- rekognize
buy zx2 struts and bore out your perches. they're cheaper and better than stock replacement.
Alright thanks guys! Okay.. you ready for this? Here's another special! wtf does this do and where would it go and how could it possibly work!?
THE PERFORMANCE CHIP! hahaha. Remember.. i dont ever. EVER! plan on EVER getting this shiz i just like knowing if any body has ever tried it! haha
http://cgi.ebay.com/ebaymotors/REAL-PER ... ccessories" onclick="window.open(this.href);return false;
or this one! it actually has a picture
http://cgi.ebay.com/ebaymotors/real-per ... ccessories" onclick="window.open(this.href);return false;
- rekognize
Save your money for an engine swap...
wasn't planning on buying it just wanted to know what it did haha okay. so whats the easiest engine to buy and just drop in. and when i get that engine what stuff do i have to buy to make it work?
- rekognize
http://tinyurl.com/ap9ro3" onclick="window.open(this.href);return false;
Are those spots on the hood 'fisheye' caused by oil in the lines from the compressor. You can buy fisheye additive that may help stop that from happening. You talk about block sanding. I thought primer is usually lightly sprayed on then block sanded. Why did you paint first, won't it be a long process now to block sand it all down? Other than my own tendency to over criticize looks like your doing a great job. Congrates. ![Smile :)](./images/smilies/icon_smile.gif)
The fisheyes that happened in my case were becuse of pin size bubbles in the bondo that weren't sanded throughly enough. And we have 3 water traps along with the one thats on the compressor ill put up a picture of it. so i really dont think much liquid is getting through the gun. and the spots on the paint are more likely dust that wasn't cleaned off good enough.Daninski wrote:Are those spots on the hood 'fisheye' caused by oil in the lines from the compressor. You can buy fisheye additive that may help stop that from happening. You talk about block sanding. I thought primer is usually lightly sprayed on then block sanded. Why did you paint first, won't it be a long process now to block sand it all down? Other than my own tendency to over criticize looks like your doing a great job. Congrates.
We spray on the first coat of paint to see how it looks from there. and nahh wetsanding the whole car with muh dad took about 20 minutes to half an hour. using 400 grit with soft pads:D Pictures coming!
![Image](http://i685.photobucket.com/albums/vv211/rocky_bebb/RockyMX3026.jpg)
Starting from far left to middle to right on mounted on the walls on the water traps. You can see the air hoses going in and out of them. These get filled with water and have nozzles on the bottom that can be opened up to release and fluid build up! Pretty niffty.
and this is how my car looks as of today and the last coat of paint will go on very sooN!
![Image](http://i685.photobucket.com/albums/vv211/rocky_bebb/RockyMX3027.jpg)
Got the silver on today!!!
![Image](http://i685.photobucket.com/albums/vv211/rocky_bebb/RockyMX3031.jpg)
![Image](http://i685.photobucket.com/albums/vv211/rocky_bebb/RockyMX3030.jpg)
![Image](http://i685.photobucket.com/albums/vv211/rocky_bebb/RockyMX3028.jpg)
This is for all you guys who thought my car was resting on its rotors!!! Come to find out, ITS NOT!solo_ryder wrote:Why are you letting the car rest on the rotors when there is no lugs holding them in place? That is gonna mess up your rotors/calipers/pads...
Other then that, good work. That is cool that your old man is heping you.. My dad just thinks my car is to loud and WAY to low
![Image](http://i685.photobucket.com/albums/vv211/rocky_bebb/RockyMX3032.jpg)
ITS DONNEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
![Image](http://i685.photobucket.com/albums/vv211/rocky_bebb/RockyMX3048.jpg)
