[WTB] K834 ECU chipped or not
looking for a 94 mx3 ecu 5 speed it can be chipped or not...ecu number K834...thanks
1993 MX-3 w/ straight neck KLZE swap...Probe GT 2.5in headers, Custom exhaust w/ test pipe and OBX Twin Loop Tip, Bully Stage 3 Clutch, Fidanza Flywheel, Pheno Spacers, HEI mod, Blaster SS coil, Probinator chip, TWM short shifter, AWR front and rear mounts (88 Durometer), and Corksport braided clutch line...so far
Ever see the lone rider of the night? Well he'll find you and then you'll never him again...
Re: [WTB] K834 ECU chipped or not
i have a 94 mx3 k8 ecu 30+shipping?
hi dont know if anyone here could help but i found a ecu on ebay and he dies not know if its for a manual or not i have the number but is there somewhere in here that has the decode for the ecu numbers to fine the type of motor and trans thanks
heres the number
B6DF 18881A
heres the number
B6DF 18881A
- solo_ryder
That's a 4 cylinder ecu for a b6.
As for the people that need k834 ecus and wanna get em chipped, make sure u check the chip serial with probinator because not all k834 ecus can be chipped
ok but is it for a automatic or manual and a dohc or sohc?
- solo_ryder
Why are you jacking this thread
becouse i have not found a b6 ecu thread and if i started on i would not get help .
