selling: make your own turbo project parts
I bought parts to turn my 1994 1.6L DOHC MT Mx-3 inot a screaming turbocharged machine. I've been gathering parts since last winter so I could do this conversion this year but now my dreams are dashed.<p>Bought an old house, that takes up my weekends, got a new job, that takes up my daytime, got a new child, that takes up the rest.<p>Anyway, I don't have time to do anything else so here is the listof parts I have:<p>1 t3 turbocharger from a nissan (no play but I would rebuild it before putting it on my car)
2 mitsubishi eclipse intercooler
3 blow off valve
4 dual electronic turbo timer/boost gauge
5 rising rate fuel presssure regulator
6 4 450cc rx-7 used fuel injectors
7 mazda 323 gtx turbo exhaust
8 capri xr2 turbo exhaust pipe
9 suburu wrx hood scoop<p>parts go to the highest bidder
3 blow off valve
Re: selling: make your own turbo project parts
I'm interested in the RRFPR and can you email me some details on the timer and what you have for a manifold.<p>cmorrison@gotmail.ca<p>Thanks,
Cheers
Cheers
No Sig
I'll get the specs together for the RRFPR. The turbo exhaust manifold is off a mazda 323gtx
what year are the rx-7 injectorsoff
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
how much for the whole list?
Speed Kills - Drive a honda, live forever...
What year is the eclipse intercooler off of and how much?
91 Eagle Talon Tsi AWD *RIP*
The specs on the RRFPR is a BOSCH #189 thst is set for 32-68 psi. The exhaust manifold is off a mazda 323GTX turbo, no cracks.
- papa roached
im very interested in the manifold, name your price
here is the rundown on the turbo project parts:<p>turbocharger- T3 Garrett from a nissan, don't know which one- will let is go for $125 USD<p>turbo timer/boost guage- Blitz dual turo timer/boost guage JDM- $110 USD<p>intercooler- off a Mitsubishi Eclipse, don't know which one- $50 USD<p>turbo exhaust manifold- off capri XR2 turbo-$65 USD<p>460cc fuel injectors- 4 injectors off a RX-7 turbo- $50 USD<p>fuel pump- 1991 Mazda RX-7 Turbo- $50 USD<p>mechanical boost controller- $20 USD<p>Rising Rate Fue lPressure Regulator- MSD RRFPR rated 32-68 psi still in box<p>adjustable cam gears- off Mazda 323 GTX Turbo- $70 USD<p>BOV- no name brand- $20 USD, with hose and hardware<p>turbo exhaust downpipe- off Capri XR2- $70 USD<p>hood scoop- off Subaru WRX- $80 USD
- The_Great_Tonge
dibs on the cam gearsm just gotta know what kind they are....
- The_Great_Tonge
cam gears have no name on them so i have to assume that they are stock oem from a 323gtx turbo ones. The cam gears are the same diameter and have the same gear ratio as my stock oem 1994 mx-3 1.6L dohc.
$55 USD for the RRFPR
