need help getting it running... spark, fuel, juice?
ive got a 94 klze 5 spd that wont start and before it wouldnt start it just died, it spit and sputtered, so i figure maybe its the distributor. i need a 94 k8 distributor. another problem is , yesterday i went with a brand new battery and all i got was click....no power, click ,....no power so maybe theres a bad ground? also i cant seem to find the fuel pump relay or fuse because the fuel pump does not come on unless i hook it right up to the battery(which i did) any help would be appreciated thanks
- johnmx3ze
Re: need help getting it running... spark, fuel, juice?
your fuel pump relay and fuse is under the hood on the drivers side...angrygumball316 wrote:ive got a 94 klze 5 spd that wont start and before it wouldnt start it just died, it spit and sputtered, so i figure maybe its the distributor. i need a 94 k8 distributor. another problem is , yesterday i went with a brand new battery and all i got was click....no power, click ,....no power so maybe theres a bad ground? also i cant seem to find the fuel pump relay or fuse because the fuel pump does not come on unless i hook it right up to the battery(which i did) any help would be appreciated thanks
Hmm, fuel pump and disty = crank sensor. I'd check that. Check the power wire at your starter. I peeld back a little insulation and found mine was corroded all to hell. (DISCONNECT THE BATTERY FIRST). I cleaned it up and car starts fine now.
as for the relay and fuse, it says no where on the caps for the relays and fuses about fuel pump. and does any one have a crank sensor? how much of a pain is it to put on ? and could that have been my sputtering problem when it was running?
so the crank sensor turns on the fuel as well as spark?
