Lol, g series transmissions don't like 300whp :)
- se7en
So I was 'racin' a 300c with a hemi, and worked him....but after, I couldn't shift into third
it's kinda funny, because I knew it was going since it popped out the other day while I was driving...oh well, new trans time I guess....anyone have a g-series to sell in alberta?
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
Re: Lol, g series transmissions don't like 300whp :)
I have a MX-6 tranny...
93 MX-3 2.5 KLZE - KL101 \\ H&R Springs \\ Short Shifter \\ 17" ADR Rims \\ 205/40/R17 Namkang Tires \\ Millenia Manifold \\ Rockford Amp \\ Rockford 12" Sub \\
--- K8 was my gateway drug.
first and third are the weak link along with the thrust section of the gearbox.
A GTX third gear is the strongest "stock" gear availiable.
- tehbrookzorz
- Yoda
HP doesn't kill your gear is the torque.
The ones from a G series diesel gearbox will survive with 268ft/lb torque day in and day out with a full new car 100,000km warranty.
- onlytrueromeo
Is that the supposed 323 diesel gearbox? Where would you go about getting one of these besides harassing importers about them?
- tehbrookzorz
Yoda and Kiwi posting in the same thread? This hasn't happened for a little while... Who turned on the Improbability Drive?
Cody
one word "Torchwood"
Im in a bit of a better situation having RPM engineering in NZ and PAR in austrailia both
having made custom gearsets for the G series box.
Yoda would know more about the 323 diesel gearbox, the 323 diesel was never imported
to NZ as a new car. I have no idea what the ratio would be.
However The missues nagged me to death about letting her dragrace the car as at the
moment Im not able to drive.
result one broken gearbox again!
- se7en
'I wonder if kiwi could get me a new third gear set' ?
- tehbrookzorz
Given that the GTX is a oem/jdm part your local mazda dealer would be able to get you one.
( Ok might be 6 weeks from japan like my diff ) but then again seafreight for 15kgs is a dam
sight cheaper than air frieght.
Im currently going back to the drawing board after the missues toasted the box, still she has
the better 60' time of 1.76 compared to my 1.8
Not her fault, she normally races DYO instead if heads up, and the pressure / excitment on the
night got to her after getting into the top three, she did'nt reset the limiter to soft for the tree
and dropped the clutch at over 9000rpm ( something has to give )
Personally ID love to toss out the diff and have a mini spool instead, less weight and no hassles
Not that I can't afford a quaife, my build has been about what I can use off the oem shelf or
modifiy off the oem shelf.
Most of my development of the car has been in the suspension side, and engine / gearbox mounting.
and weight distrubuion in the car itself, that is where the gains have been made not the motor.
The Edmonton pick n pull has 3 GS's as of yesterday.
Whoa, whoa. What's this about a diesel gearbox? That sounds like it'd have a very low final drive ratio and/or gearing ratio!
The G series tranny mates with the K series engines, right?
I would love a final drive ratio more around 3:1; all I get is wheelspin in 1st and 2nd anyway. If I could do 100km/h at 2000rpm it would be a dream come true.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
- Ryan
If its got the right bell housing, yup. All G series internals should be interchangeable.
Does anyone have more details on this diesel tranny? I can't seem to find much on google.
What's the part #? Final drive ratio? Gearing ratios? Same engine mount locations? Price/availability? LSD-swappable? I'm excited about this!
- Gord
