MILEAGE POLL...Just curious!
2RotorsNaDream
Re: MILEAGE POLL...Just curious!
Wow anna brought this back from the dead. I remember reading this post before I bought my first MX3 to see how reliable they were and before I actually registered into the forum. BTW my black GS had 106,000 miles on it when I bought it. It drove beautifully until I blew it with 132,000 miles on it. It was my fault though, no oil change. My new KL-03 has 35,000 miles on it. So I've got a long time to play with my MX.
1993 Mazda RX-7 Touring Edition Innocent Blue Mica- Not stock...1993 Teal MX-3 GS- KLZE and other goodies. RIP
Tyler17rose
218 000km's , bought it with just over 200000km's
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
Bought mine with 142,xxx and now it has 151,xxx. I think a little under 2 years I have had it before I did the swap.
- papa roached
got it with 114K on it, just rolled 120,000
MadHatter
I bought my 94' MX-3 about 3 and 1/2 months ago with 79,000 miles on it, now it has around 82,000 and still running very great. Last major fix was the braking system but those are understandable.
I am the MadHatter.
stupidtickets
Bought my '95 rs months ago with 111,000 miles. Now i have 126,000 new cv joints and water pump.
stupidtickets
that would be 9 months ago and add a battery to that list.
bought my 92 GS last june with 109k kms on it, its upto 144k, ZE swap was done at 141k
Csillag
'95 4 cyl bought 3 yrs ago in Nov. at 68Kms, I'm at 192968km. And I haven't even gone anywhere!
Life's short, live it up!<p>http://www.cardomain.com/id/csillag
quicksliver
Bought it with 106,000km's January 2002. At the moment it has just over 167,000km's on it...<p>I have put $1100.00 into the engine. Why? One of the cam shaft friciton gears started ticking.
Johns93GS
135,000 miles. She went to the shop today for engine compression tests
i have 83,000 at the min maybe the transplant at 100,000
check my car domain
http://www.cardomain.com/ride/2144443
philcosta
1993 RS with 110 000 KM and now i have 60000km (bpt swap)
http://www.cardomain.com/id/phil_costa
<img src="http://smkclan.com/images/snake/articbeast.jpg" alt=" - " />
1992 1.8 V6 with 225.000 Km on it and it still runs great. Needs a bit more oil, but thats all.
nov,02, 73k - Present 113k
96' Blaze Red
Kicker CVR 12"
PG 250.2
JVC kx980
PG QX 1.0
Kicker CVR 12"
PG 250.2
JVC kx980
PG QX 1.0
