Anyone else have this problem ?
markm
Post by markm »
Hey guys, i have a problem with my fan blower motor i think. My interior fan only blows hot/cold air on the 4th level. Has anyone had this problems before ?
onlytrueromeo
Re: Anyone else have this problem ?
Post by onlytrueromeo »
My friends truck does this and has not looked into getting it fixed, haha. Electronics maybe?
markm
Post by markm »
yeah its a real pain in the a--, hopefully its something to do with the motor.
Ryan
Post by Ryan »
slider or button controls?
For your sake... nope, nevermind. Both situations suck royal ____ (insert noun of choice)
aufgehdraht
Post by aufgehdraht »
wild guess could it be something stupid with the blend door? i know in most cars its a pain in the a-- to get too but they are usually super easy to fix once you do get to them.
Ryan
Post by Ryan »
There have been threads on it quite recently, and I suppose I'm expected to go find them for you, because I know what I'm looking for and you don't, so it only makes sense I'd do it, right?
http://www.mx-3.com/phpBB3/viewtopic.ph ... er#p303506" onclick="window.open(this.href);return false;
There's a relevent one, but I've gotta go, so good luck.
http://www.mx-3.com/phpBB3/search.php" onclick="window.open(this.href);return false;
markm
Post by markm »
Thanks alot, that post helped a bit. I'll just have to look into it soon. Next time nice weathers around. Thanks Ryan
BlackMazdaMx-3
Post by BlackMazdaMx-3 »
If it only works on the 4th setting then the blower motor resistor is burnt up. If it blows hot and cold air at the same time then a blendoor is broken. Not exactly sure what you are meaning but thats what i know.
93 Mazda Mx-3 rs,BP-T swap,22psi,custom fmic,Custom 2-1/2 downpipe with external dump,2-1/2in downpipe back exhaust,Tuned with Megasquirt on E85,Mazda protege G-series transmission,GS rear disk brake swap,H&R lowering springs,corksport front/rear strut tower brace. Dynoed at 300hp and 330tq Mustang dyno, 8.5@87mph 1/8mile http://www.cardomain.com/ride/3139490" onclick="window.open(this.href);return false;
93 Mazda Mx-3 GS,BP swap. Daily driver
