CRUISE CONTROL
CRUISE CONTROL
I was wondering what would cause the cruise control not to work, it doesn't work at all and i had it in my other car so i know i am doing it wrong i don't know if someone maybe could of disconnected or something.<P>Jamie<BR>95 mx-3<BR>sparkle green
Re: CRUISE CONTROL
not to seem condesending, but are you sure you are using it right. it took me a month before I accidently figured out how it worked and the previous owner never new it did work. you push the cruise control on button and then use the lower button on the steering wheel. you have to push it, then push it and hold it for a sec. then take your foot off the gas and it should work. that's the only way mine works anyways.
- Andrew_Pakula
Re: CRUISE CONTROL
Too be honest I'm not sure how it even works, I bought my car used like 3 years ago and I tried to turn it on a few times without any luck, either I'm not doing it properly or it doesn't work. Either way I don't really care because I would rarely use it.
Re: CRUISE CONTROL
Cruise contriol is the best thing ever made you get so much better gas mileage when using it. But any ways when you push the cruise control button does the little orange light stay on?
Re: CRUISE CONTROL
lol, I can't believe this. All you have to do is turn cruise control ON, maintain a constant speed for a couple seconds, and press the set cruise control button on your steering wheel ONCE, and its set. It's so simple!
<img src="http://members.rogers.com/zytariuk/images/mx-3.gif" alt=" - " />
1992 Mazda Mx-3 GS - Beige metallic
zytariuk's mx-3 page (updated June 12th, 2003)
Re: CRUISE CONTROL
hey i checked out the cruise control and someone disconnected it. but we couldn't find were to connect it. the garage search for two hours and he used his software that he had and couldn't find were to plug it in. does anybody know?
