does the TNS relay deal with all the side marker lights and parking lights on the front and back? or does it deal with little or more of the things i mentioned. my instrument cluster gauge lights dont work and neither do my park lights on the front and back, and the side marker lights on the front and back dont work either. is it possible its the relay?
ive got a wiring diagram pulled up and it looks like it might all lead back to that tns relay.
http://mx-3.com/manuals/showimg.php?fil ... /Z-072.gif" onclick="window.open(this.href);return false;
if it is the relay, ive been looking for one just in case, but cant find any, do they have a different name or something?
93 mx3 rs
TNS relay help
Re: TNS relay help
ok so on this link
http://mx-3.com/manuals/showimg.php?fil ... Z2-044.gif" onclick="window.open(this.href);return false;
it shows going across A-B you should get continuity, and across C-D you should get continuity. i did the test and i got continuity on one of them, but not the other. i did the test with the ignition off, so does that mean that the TNS relay is bad?
tom
