Well I took the plunge and bought the Ground Control coilovers to pair up with my ZX-2 struts. So I started the work of replacement this weekend and figured I'd try a rear corner to start. I guess I was a bit surprised at how the pieces fit. The sleeve of the coilver simply resting on top of the bottom 'shaft' of the strut itself? Here's a picture to show you what I mean. Please let me know if this looks correct. At first I was like, 'hmmmm....did I receive the right kit from GC?'
In any case, once I had the strut assembly back together I started with the coilover collar threaded about halfway up the coilover 'sleeve'. When I had everything together and lowered the car I ended up with a 4.5" gap betweep top of my tire and the bottom of the fender. Does this sound right? From your guys' experiences, how far will I be able to lower/heighten from there? I had the H&R springs in before, which left me with a 1.75" gap previously, so obviously I have some adjusting to do if I want to get anywhere close to where I was.
Also, what have you found is the best method of adjusting the coilover once it's in place? Channel locks? What's the best tool?
Any of your experiences and advice is much appreciated.
