Engine noise
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
headcut
Engine noise
Post by headcut »
I am from Portugal and i have recently adquired a MX3, but i am a little concerned about a metallic noise it makes when i start the engine when it is cold and it gets away when engine is hot!
Can someone tell me what this could be???
ReMXed-95
Re: Engine noise
Post by ReMXed-95 »
have someone start the car for you, while you go listen in the engine bay for where its coming from. does it sound like metal on metal scraping or like a valve clatter sound?..
KYB-GR2 struts, BG 2" lowering springs, Pearl red paint, Tint, Carbon tails, Short ram intake, Engine swap, Short throw shifter, Custom interior, 2 12" subs, Custom sound, Mazdaspeed ignition, K2 smoked mirrors, Front/ rear Corksport strut bars, Shaved rear wiper, Motegi MR7 17" gunmetal rims with ZR rated low profiles, RS 14" Honeycomb rims, Upgraded brakes and lines and alot more http://www.cardomain.com/ride/3085354
fowljesse
Re: Engine noise
Post by fowljesse »
Use the search function in the red bar under the MX-3 ^^
It's normal.
Welcome to the boards :)
PatMX3
Re: Engine noise
Post by PatMX3 »
It could be the water pump. My engine is making the same type of sound.
"93 Mazda MX-3 GS. Special Edition* 1.8L
Color -Rasberry Metallic. P-START Ignition*.
EuroLITE Dash Gauge* 77,000/m
#2nd Mx-3 Owner.
Mazda. Get in. Be M o v e d .
nsngarage
Re: Engine noise
Post by nsngarage »
Could he may be talking about the HLA's? If so.. welcome to MX-3 :)
93 MX-3 GS SE -- KLDE Motor, Full Drift Kit w/molded rear/sides. Project Airbags in the near future!
88 Toyota SupraT -- Complete teardown rebuild this winter! MX-3 Took priority in the garage! >:)
Return to “Engine Electronics/Tuning”
