lowered my car: eibach/tokicos -- some afterthoughts
eyezpinned
Post by eyezpinned »
i just finished lowering my car a few days ago: eibach springs (1.5f/1.2r), tokico struts. i'll post some pics later today. my afterthoughts:
the install:
surprisingly easy. there's a write-up on here that is an awesome reference point. basically a set of jack stands, a 17mm and i believe a 14mm and your good to go. i tackled it with a friend. we threw it on jack stands (back, then front). he did one side and i did the other. we had a small compressor and air tools, and we knocked the whole thing out in like 2.5 hours including doing the brakes. TRICKY PART: if you have rear drums, some of the brake line is metal. after installing the struts you may have to bend it a little to get the clips back in. otherwise it was simple.
the look:
the wheel gap is almost eliminated, but another half inch would have probably been perfect. i got the whole setup for $160 so i'm not complaining.
the feel:
the ride is great. more aggressive on bumps, but definitely still very tolerable.
alignment & camber:
an alignment is a must. had a bit of negative camber in the back, but the alignment corrected it. alignment i think really helped me appreciate the upgrade more. your car can probably use one anyway, so dont skip it. car drives a lot better after.
rubbing:
initially i was worried about rubbing because the gt3s i bought were wrapped in 195/60/15 tires. bottom line: on this setup they don't rub.
93 rs: tokico struts & eibach springs, 15' rota gt3s, cf hood & gas lid, 2.5' exhaust w high-flow cat, tranny cooler, reupholstered seats, custom black interior, chrome miata handles, momo wheel & ebrake, spyder black projector lights w hid, altezzas, clear corners/sides, eclipse 8454 hu, diamond hex components w/ 3-way add-on & an re se 15' powered by 300/2v2 & 500/1 jl slash amps, corksport mazdaspeed bumper, euro mini sideskirts, fresh paint
RS_OBD'oh_2
Re: lowered my car: eibach/tokicos -- some afterthoughts
Post by RS_OBD'oh_2 »
wtf? $160?????
The springs alone cost more than that.... and each strut.
Who do you know and why are you not sharing with everyone else?
tehbrookzorz
Post by tehbrookzorz »
It's not just the camber that will be off. Your toe will be out badly until you get an alignment, and that'll scrub off tires faster than a little negative camber.
Cody
hotsiit
Post by hotsiit »
Great review, but also Awsome price! ....
...Waiting for pictures :D
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
eyezpinned
RS_OBD'oh_2 wrote:wtf? $160?????
they sprung up on ebay 2 or 3 weeks ago from a canadian auto parts recycler. the setup is used, so i was taking a risk, but after exchanging a few emails i was pretty confident they were in good shape. i was also given a warranty. they were off a 96 with 110,000 km so like 68,000 miles. im guessing the struts/springs have 1/4 of that because they look great just a little dirty. the thing was the ad was worded funny and didnt come up on most searches. i posted a few pics of my car and everyone was saying how it would look better lowered and they just popped up. i swear it was like divine intervention. god must have an mx3 in his garage.
RS_OBD'oh_2
wow.
You've got some pretty good luck. I'm using the same setup and I'm sure it cost me over 800 for everything.
fowljesse
Post by fowljesse »
Oh,oh oh... If your car doesn't have it, get the 22mm rear swaybar off of it. If your car DOES have it, get it for me, and I'll buy it from you!
Please?
Flyer
Post by Flyer »
fowljesse wrote:Oh,oh oh... If your car doesn't have it, get the 22mm rear swaybar off of it. If your car DOES have it, get it for me, and I'll buy it from you!
Please?
Wait, does the 1996 MX-3 have the 22mm swaybar?
fowljesse
Post by fowljesse »
Purdy sher they do.
RS_OBD'oh_2
hmm.. will have to check that out.
fowljesse
Post by fowljesse »
Also European ones.
