So i tryed switching the resistor that we talked about above and it made not difference. The stock resistor was a 51ohm, i tryed a 27ohm, 10ohm, 1.5ohm resistor and they all flash at the same speed. So
I need help to disable the load sensing circuit in my flasher so it will flash at a normal speed. I have installed LED turn signals and it flashs really fast.
How can i slow my signal lights down, flashing too fast
stephen-mx3
Re: How can i slow my signal lights down, flashing too fast
i now this is one old a-- thread, but is this?!
i dont fancy buying 6 of those load resistors!!
Just get higher viscosity blinker fluid.
Re:
yea i thought it was illegal so have fast blinkers...hyper blinkshameem wrote:P.S. - I was ok with my leds flashing faster than normal till i got pulled over and "warned"......
94 mx3 rs
