2 noob Qs
- Tropical Emerald 1993
2 noob Qs
1. my right headlight and left foglight are not working. What to check?
2. does this car have position lights. If does, what to check if they're not working?
Re: 2 noob Qs
1. bulbs?
2. well if you have the leveling switch on the interior and small motors on the back of the lights then they are "positioning" as you call it
I've been trying to find wiring diagrams for months with no luck on how to get mine working (assuming the motors still work).
Re: 2 noob Qs
If you cant find diagrams anywhere - send them to me and i will figure it out for you and send them back.Mooneggs wrote:I've been trying to find wiring diagrams for months with no luck on how to get mine working (assuming the motors still work).
Re: 2 noob Qs
1. bulbs are fine, I was looking for a fuse but cant find it.
2. position lights are small ones, used for daylight and most cars have them.
Re: 2 noob Qs
yes, the car has position lights (near the blinkers).
What do I need to check except bulbs?
Re: 2 noob Qs
ah I see so position lights = DRL... that was a canadian feature (so I have no idea)... maybe the DRL module went bad?
Re: 2 noob Qs
ok but WHERE are modules/controlers/fuses for the all these lights?
- Savin
Re: 2 noob Qs
I think the DRL module is right above the driverside strut tower. I have a bracket for it, but no module/wiring. Check there.
I think its there, I could be very wrong.
'93 MX-3 GS - SOLD!
'93 MX-3 GS SE - Parts car!
'94 MX-3 GS - Scrapped
'94 MX-3 RS - Scrapped
'96 Sunfire SE - Scrapped
'03 Sunfire SE - Deathtrap
'95 Cavalier Base - Scrapped
'89 Mustang GT - SOLD!
'93 MX-3 GS - SOLD!
Re: 2 noob Qs
thanks man, but I got nothing there either. And I need to find another one for the front right light (and left foglight).
Re: 2 noob Qs
I never knew what that was for, thanks
- Savin
Re: 2 noob Qs
This came up when I searched DRL:
http://www.mx-3.com/phpBB3/viewtopic.ph ... &hilit=DRL" onclick="window.open(this.href);return false;
You might be able to get more from the info there then I can.
'93 MX-3 GS - SOLD!
'93 MX-3 GS - SOLD!
Re: 2 noob Qs
ok, seems I have to draw
Re: 2 noob Qs
left light started working for no reason
This car is crazy. I'm still looking for a way to enable position lights.
Re: 2 noob Qs
Tropical Emerald 1993 wrote:ok, seems I have to draw![]()
love the diagram very fool proof
Re: 2 noob Qs
ok I got a problem again!
left headlight does not work on low beam, works on high beam. Its the same bulb I think
How is that possible and what to check? Thanks.
