WITH THE CAR PROPERLY SET UP DID WELL IN THE QUARTER
- stereoking15
so, after figuring out how to launch the car with minimal wheel spin (1200-1500 rpm) acting like coming from a stop sign i ran tons of 14.1 q's at 98-99 and fastest of an 14.084 at 99 and 2.194 60' time. tires were falken rt 615's 235/40/17 aired to bout 26-28 lbs. still open diff.
94 gs ze swapped,front mount oil cooler,b&g springs, kyb gr2 struts, vris deleted, gutted, racing 4 point harness. centerforce dual friction clutch, BREMBO ROTORS X4, CARBOTECH XP10 front pads, ebc green stuff rear PADS, corksport brake lines & clutch line, hei mod w/ msd blaster 3, MAZDASPEED motor mounts, B&M short shifter, M-FACTORY LSD, Carbon fiber hatch with lexan window.
- Ryan
Re: WITH THE CAR PROPERLY SET UP DID WELL IN THE QUARTER
Pretty awesome man, what are you running? Wait, I'll just read your sig.
and somehow you managed to make two new threads of exactly the same thing? actually 3, one has a different name.
- fieromx3
u dont even have a cai? according to ur link pictures
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
- fowljesse
That's great! I wondered how you'd do. It gives me hope. If you go again after the 19th, I want to go.
That's how I was imagining I'd do it... Low RPM launch, and then hit it.
- marcdh
Good work Fieromx3, in his photos it looks like he cut a big hole in stock airbox, does the trick I'm sure
View Worklog
View Worklog
sweet mx3..you gotta be the only person ive seen runnin (what appears to be) stock intake, whats up with that if u dont mind me askin?
- stereoking15
haven't had time nor the real money to domy own set up on the cai yet after the total project u can check my myspace and check out my pics of how the car started
[url][http://viewmorepics.myspace.com/index.c ... 859895/url]
in order to see myspace pictures you have to have a myspace account...and on yours you have to be added as a friend to cause your profile is set to private.
are there more pictures on there? i wanna see!!!! haha
Never be afraid to try...amateurs built the ark, professionals built the titanic.
- stereoking15
check now i just changed it, lots of pics
um the profile is now no longer set to private but the pictures still are
- stereoking15
ok i think i finally have it worked out
Thats a real great time man. Especially without a CAI. I know these cars will do mid to high 13's on sticky tires. Its all about the launch. I ran a 15.0 at 98. Trap speed is there but my 60 ft time was a 2.8. I think with a 2.0 60 ft time id run a 14.0 at 100 mph.
shouldnt this be in the drag and track forum?
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
