Swappable Intakes?
Swappable Intakes?
I have herd you can use a Dodge neon cold air intake and i have also herd u can use a honda civic cold air intake. are any of these true? if so can u use it on a 95 DOHC?
- umcamara
Re: Swappable Intakes?
Search on here for Integra intake...
It's just a pipe, as long as you got the right basic shape, and some couplers that will work with the air flow sensor and intake manifold, you can make almost any work.
