[WTB] 92-93 wiering harness for v6
i am looking for a harness ..i put in a kl-de ..and it wont run cause i am obdII so any one have one on a parts car or something perferably close so i can pick it up asap...thanks
Re: [WTB] 92-93 wiering harness for v6
OK, a KLZE will run great with a KL02 VAF on OBD2. I just bought one off a Probe. For some reason they said to use a Fuel Pressure regulator set to 45 PSI (not sure why). Check your sensors e.g. O2, they're not the samevoltage, clear your codes and adjust your TPS. Search the recent posts you'll get all the answers you need here. Changing harnesses is a really big job. If you chose to go that route just get the OBD1 harness plugs (3) and adapt it into a OBD2 harness. You'll need to go to the dealer to photo copy the schematics. "Good luck" NEXT,,,
let me know if you still need the harness and I will inspect mine to see if it is in good shape in the meantime.
Garage (sort of)
99 Acura Integra GSR-T (totaled)
03 Mercedes Benz C230K (rear upgrade from 3.27 to 3.67 ratio) running strong at 108K miles
92 MX-3 v6 (that i wanted to twin turbo w/ an ht12 and ht15) - Parting out now!!!
90 MX-5 getting the rotary treatment
bdavis2005 @ gmail . com
feedback link -> http://www.mx-3.com/phpBB3/viewtopic.php?f=37&t=62911" onclick="window.open(this.href);return false;
