Third Link Bushing Mazda Part Number
Hey guys I want to get the third link bushing from the dealer, but they can't seem to find it. Do you guys know the part number for it?
- mx3autozam
Re: Third Link Bushing Mazda Part Number
you can't get it at mazda. the shift linkeage is all one piece. the SRD kit requires you to drill it out to install the bushings. You can do that if you want and just install oem bushings.
93 Mazda MX3 KLZE Turbo
That is the point.....Which oem bushing? ![Shocked :shock:](./images/smilies/icon_eek.gif)
shifter bushings? SRD part # S1401
as found here:
http://www.mx-3.com/am-parts.php" onclick="window.open(this.href);return false;
looks like they are $35 a set tho.
http://corksport.com/store/category/53f ... train.html" onclick="window.open(this.href);return false;
a quick search led me to http://www.mx6.com" onclick="window.open(this.href);return false; a thread there leads to mx3 & mx6 bushings being the same and (mx6) bushings can are about $20 at dealership. original post below:
Quote:
Originally Posted by mazdamoron
Someone chime in here and either verify this or shoot it down for me, but I'm fairly sure the MX-3's shifter bushings are the same as the mx-6... They should be the same at the end of the shift rod, at the transmission, if nothing else...
Those rarely get much wear at all as long as the two large washers on the sides are not removed (lost during a tranny change perhaps).
I cannot see the bronze ones you're suggesting being any benefit over the OEM replacement ones which are under $20 for the pair from Mazda for the MX-6.
as found here:
1995 MX-3 1.6 DOHC 5SP.
The question still remains which oem bushings do I put in if I drill the third link bushing out? Is it the same as the other 4 shifter bushings?
Bump!
Can anyone please answer my question?
The 3rd link bushings are the same as the bushings at the bottom of the shifter.
2003 Subaru WRX
Thanks a whole bunch!!!! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
