i was looking for some springs that would lower my car some and i came acrosses a set of tenzo racing springs. they are like $120. Any good or bad comments about them? or how about a decide recommendation.
Thanks
Tenzo Springs good?
- 92StockMx3
Tenzo Springs good?
Mike
1992 Krylon White Mazda MX-3 RS. Cold Air Intake,17 inch Voxx rims with Toyo Proxez 4, Black Projectors, Black Taillights,Smoked Turn Signals.
1993 Brilliant Black Mazada MX-3 GS. KLZE, Short Shifter,
- solo_ryder
Re: Tenzo Springs good?
Tenzo doesn't make bad parts. Lowering springs are usually all very similar, they should be fine.. If you just want a lowered look then you probably dont care about performance so much these will work fine.
- 92StockMx3
Seems logical as for struts i see KYB GR-2 struts for a decent price. Do they just go together or is there a certain way to find a right size or something?
Mike
- solo_ryder
Yea, those will work. They are more like a OEM replacement, so the valving is not as aggressive as you would want for the springs, however they have a lifetime warranty so if they blow up you can get new ones. Another option are the Tokico HP's or do what I did and get the Ford escort ZX2 shocks from Ford racing, about 230 bucks to your door and they only need a tiny bit of modding!
