Interior fuse and clock issues!
Aston Wards
Re: Interior fuse and clock issues!
Post by Aston Wards »
There's a wiring diagram in the online shop manual
It's probably what Kirk said...., the door switch shorting out
*edit*
I was just txting the new owner of my car and i remembered something....,
i had disconnected the door buzzer on my car, try this.....,
under the fuse box there is a long-ish connector, i'm not sure what all the wires are for, but i'm pretty sure for this part you can just pull the whole thing out...., now chuck a fuse in, if it holds then it's your door switch i reckon :mrgreen:
somehow i worked out which wire was for the door switch without using a wiring diagram or a multimeter, but with no car, i can't tell you which one :roll:
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
solo_ryder
Post by solo_ryder »
HAHAH
Well, I certianly thank you for your help here. My suspision is that it is the door buzzer as well, that is because it is located in a area that could be getting moisture etc. I doubt the dome light has a short. I will check this out when I have more time. My stereo decided to only work 25% of the time now and I have to get a new deck :(
