Online Manual Question
Anyone know if I can use the '95 Workshop Manual for my '93 GS? Thanks!
Re: Online Manual Question
wiring diagrams are not identical.
- umcamara
There is a '92 online manual, may be better suited.
Thanks! There have been noise coming from the left hand side of the engine and I want to check the manual what is on that side. I may need to check the forum a bit and see if other people are having the same issue. It sounds really weird.
Hopefully this is on the same topic... I was looking at the online manual to see if there was any information on replacing disc brakes and pads, but I didnt see it in the manual. Is there somewhere else I can look?
Thanks
Thanks
He who has the most toys wins!
- umcamara
There's an entire section in the manual on the braking system, section "P". It tells you exactly how to remove and assemble each part. What is it that you want to know? It's a very straight-forward procedure.MaX3 wrote:Hopefully this is on the same topic... I was looking at the online manual to see if there was any information on replacing disc brakes and pads, but I didnt see it in the manual. Is there somewhere else I can look?
Thanks
