When I bought my KYB GSR-2 sturts, I also bought a new boot/cover assembly, and new rear strut mounts.
I did not install them but my dads friend did (very trustworthy). I am asking you all about it b/c he's been sick and I really haven't talked to him in a few weeks.
It bugs me because it rattles when I hit bumps, and the rattling is on my nerves.
I'm also interested in the gold colored part. I have no idea what its function is.
It's only there to put the black dust cover over. The 17mm nut on top should have something like 90lbs or torque on it and there should be a lock washer inbetween as well. It should not move. Unless everyone else is correct, and the 14mm nuts were not just taken off for the pics.
Yah, to fix the rattling (and for safety) definitely need to grow a pair of 14mm nuts and put em on those exposed stud threads. They're what holds the strut mounts to the car body.
Dark_Rider2k3 wrote:I did not install them but my dads friend did (very trustworthy).
...ummm....really???
2004 Honda RC51 --- Lost forever to some theavin' bastard My Worklog My feedback thread Never attribute to malice that which can be adequately explained by stupidity.
We had to mount the seat belt directly to that spot. We tried to do it the way it''s supposed to, but the bolt was not big enough for us to do it that way.
If i'm correct, it's supposed to go nut, seat belt, and then nut, but when we did that, it did not work (there was no room to screw in the next bolt)
I hope i'm being clear, and maybe you all have a suggestion.
but yeah, that middle piece is the thing that rattles.
If the bolts are not long enough, your strut seat is not mounted properly. I believe that piece of metal aligns the strut correctly, and also allows you to properly torque the nut on top down. (You put that in a vice on the two flat sides, then tighten it) I would recommend pulling the strut out and re seating the spring, making sure everything is in 1 piece. If the bolts still aren't long enough you must have a different/wrong mount. Make sure your mount is not broken (the rubber).
onlytrueromeo wrote:Do you happen to have the old strut mount to check to see if the post lengths are the same?
When I took the struts off, the old mount literally crumbled LOL
I can try to see if I still have it, but I replaced my struts back in November. So honestly, i'm highly doubting it..
but that's where i'm almost 100% sure the problem was.
BTW, These struts were from Advance Auto if that makes a difference (cuz when we mounted them up, Rick (dads friend) looks @ me and says "you got these from advance didn't you?" and when I sad yeah, he just laughed and said "I knew it.. ")
