As most may know, on my 93, the tire size is 185/65r14 . Recently, brand new Goodyear tires with excellent treadwear, traction, temp and 660 rating where given to me. THe only problem is, they are 175/65r14. Therefore, I ask....are there any major consequences or a potential for future problems if I use these tires? THe only thing I can think of with such a small difference from 185 to 175 would be a slight difference with my speedometer, which then makes me believe there may be a increasing error reading on the overall mileage.
All feedback appreciated.
Thanks
Tires size
- tehbrookzorz
Bochek
Re: Tires size
what he means to say by that is they are 1cm narrower and 6.5mm smaller in radius this will bairly effect anything on the car and will work fine for you.tehbrookzorz wrote:They're 1 cm narrower and 65% of that width narrower.
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
- tehbrookzorz
